Comments field in Element (GB 2.0)
  • Hello, friends
    I’m still testing GenerateBlocks Beta and I have a couple of questions:
    1 – Is there any way to stop (Or add a specific message) the ‘No comments’ field from appearing only on posts that have closed comments with a filter or something? The only two options now are default and adding a custom general text for all. I hope I’ve explained
    https://ibb.co/c18T0Xt
    https://ibb.co/gvdhVgG
    2- Would using an element with this data instead of the native method have any impact on performance?
    Tnx!
    1. I’m not sure I understand what you mean by closed comments, do you mean you want to hide the no comments when there’s no comment on the post?
    2. No, there’s no performance impact.
  • Hi again Ying
    1 -I’m referring to the native WordPress option to close comments, either on a specific post or after x amount of time.
    https://ibb.co/4j1LYTf
    2- Great
  • So you only want it to hide when the comment is closed?
    and you do want it to show “no comments” when the comment is open?
  • Yes, exactly, but only show the link when comments are closed if it had some comments before closing and hide it if it had no comments.
    Could you try adding this snippet:
    add_filter('render_block', function ($block_content, $block) {
        if (! isset($block['attrs']['className']) || strpos($block['attrs']['className'], 'hide-no-comment') === false) {
            return $block_content;
        global $post;
        $post_id = $post->ID;
        // If there are no comments, return empty to hide the block
        if (get_comments_number($post_id) === 0) {
            return '';
    }, 10, 2);
    Then, on the block with the comment count tag, add a class of hide-no-comment under Advanced > Additional CSS Classes.
  • Hi, @Alvind
    Thank you very much.
    I just tried it in staging and it didn’t seem to work, do you think the block needs to be re-rendered or something?
    you could try this:
    add_filter('comments_number', function($output) {
        if (!comments_open()) {
            $output = 'Comments are closed';
        return $output;
    And don’t set any specific comment text in the dynamic data options.
  • Hi, David
    I put this new filter in the functions.php and no specific comment in the dynamic data options.
    https://ibb.co/48PTKpT
    He still does not hide it.
    It only shows the “Comments are closed” message where there are comments, but does not hide link it where there are none.
    As for example in this one with closed comments and no comments:
    https://staging.jrmora.com/test-generateblocks-2-0-alpha-2/
    I have left login details in case you want or need to look something up.
  • Try this instead, and make sure the hide-no-comment class is added to the text block.
    add_filter( 'render_block', function ( $block_content, $block ) {
        // Check if the block has attributes and className
        if (
            ! empty( $block['attrs']['className'] ) &&
            strpos( $block['attrs']['className'], 'hide-no-comment' ) !== false
            // Check if comments are closed and no comments exist
            if ( ! comments_open() && get_comments_number() < 1 ) {
                $block_content = ''; // Hide the block
    }, 20, 2 );
  • Good evening Ying.
    With this filter it hides the whole text block when comments are closed 🙁
  • With this filter it hides the whole text block when comments are closed 🙁
    Isn’t that what you want?
    Can you explain some more about what you want?
    And can you share 4 post links that are:
    1. comments open, has comments.
    2. comments open, no comments.
    3. comments closed, no comments.
    4. comments closed, has comments.
    And let me know what you want for the 4 kinds of posts exactly.
  • Well, I may not have explained it well because of the language. I will try as you propose.
    Scenario:
    An element to be displayed in posts with a GB Text block with three dynamic fields: date, post date modified and comments count.
    https://ibb.co/wRZwvtF
    Code:
    <!-- wp:generateblocks/text {"uniqueId":"b2b6b3a7","tagName":"p","styles":{"fontWeight":"normal","fontSize":"14px"},"css":".gb-text-b2b6b3a7{font-size:14px;font-weight:normal}"} -->
    <p class="gb-text gb-text-b2b6b3a7">GB 2.0 Element -Publicado: {{post_date}} | Actualizado: {{post_date type:modified}} | {{comments_count link:comments}}</p>
    <!-- /wp:generateblocks/text -->
    And what is intended is:
    1. comments open, has comments (Normal behaviour, shows link with number of comments)
    https://staging.jrmora.com/1-comments-open-has-comments/
    2. comments open, no comments (Normal behaviour, shows link “Comment” or “No comments” etc).
    https://staging.jrmora.com/2-comments-open-no-comments/
    3. comments closed, no comments. (Only the comments link count field is hidden)
    https://staging.jrmora.com/3-comments-closed-no-comments/
    4. comments closed, has comments. (Normal behaviour, shows link with number of comments)
    https://staging.jrmora.com/4-comments-closed-has-comments/
  • An element to be displayed in posts with a GB Text block with three dynamic fields: date, post date modified and comments count.
    Use a separated text block for the comments count, then the code should work.
  • OK, I’ll try to put the separate Text block in a container with two grids. Let’s see if I can square it.
    You’re referring to your last code, right?
    https://generate.support/topic/comments-field-in-element-gb-2-0/#post-148082
  • Yes, that’s right 🙂
    You don’t have to use Grid block for the layout, just add another text block, and set both text blocks’ display to inline-block.
Viewing 16 posts - 1 through 16 (of 18 total)
