webbplatsen
I want to create a grid (table) like this page https://inleed.com/hosting
Also take a look how it looks in mobile view.What is best practice using your solution?
You can build a similar layout with the Grid block:
https://docs.generateblocks.com/article/grid-overview/Let me know if this helps π
webbplatsen
Yes, but I guess I need some more guideline som create this using the Grid block.
Looks like you have GB pro so you can see lots of examples in the Pattern Library:
https://www.screencast.com/t/Uj3pOpuqThis is how to access them: https://docs.generateblocks.com/article/pattern-library/
webbplatsen
Yes I use GB Pro and have browsed Pattern Library but have not found any which reminds of my example.
The patterns should be good examples demonstrating how to use the Grid block.
If not then you can start with a Grid block with 4 containers (25%) in it:
https://docs.generateblocks.com/article/grid-overview/Here is the basic structure you need to replicate:
https://www.screencast.com/t/FWWMpBwtHLx4Please get it started so we can see what issues you have.
The best way to learn is through trial and error.
Let me know π
webbplatsen
Thanks but have seen my example?
1st row contains column titles.
In desktop view 1st column contain labels and 2/3/4 columns values. -
Yes I have seen your example and my structure should work.
Have you tried it yet? If so can you link me to the page in question so I can see what issue you are having?
webbplatsen
Here is my example.
Forget about row heights.Desktop view looks ok but when you view this in mobile view labels (Feature 1/2/3) will be displayed in top only.
Mobile view should look like;
Product 1
$1
Button
Feature 1 | YES
Feature 2 | NO
Feature 3 | NO
Product 2
$2
Button
Feature 1 | YES
Feature 2 | NO
Feature 3 | YES -
webbplatsen
I guess I solved it now π
Glad to hear π
