I have a client who may be wanting to cancel our support agreement and I want to check if she is using any premium features of the GP Theme or GP Blocks.
Can I check a feature comparison between free and paid versions?
you can check if the client site is using premium modules at appearance > GeneratePress.
if disable all premium modules and the site looks the same, then she can disable GP Premium plugin smoothly.
If not, especially if the site is using any GP elements (appearance > elements), the site will change after disabling GP Premium for sure.
Ok, thanks.
No Problem 🙂
If I disable Appearance > Generate Press > Disable Secondary Nav, it disables the secondary menu. Can you have a secondary menu in the free version of GP?
Also, can you have a background image in the header as shown on this website. When I turn off Generate Press > Backgrounds, this is removed. Is there another way to make this happen?
I have replied to those questions on your other topic.
