Conditional display not working
  • Hello, I love this conditional display feature and its been working great, except for this one instance.
    It’s going to sound complicated, but its really simple.
    I created some ACF fields attached to a custom “Experts” post type, and I have a couple conditional display conditions that exist already, applied to some containers, which work just fine. For example “Display if post meta exists = hourly_rate” – so the container only displays if that acf field exists.
    However, I used the exact same logic to display if “years_experience” post meta exists, and its not listening > instead ALWAYS showing the container.
    It might be easier if someone logs in to check all the settings but as far as the dynamic post meta settings goes> they are required to render the same as others with functional conditional display
    I must be missing something silly somewhere.
    but the condition follows the same logic
    the dyanmic text follows the same logic
    and acf field follow the same logic
    However the conditional display does not listen, and still displays the container.
    I’m going to add the url, and some login details to prviate.
    I tried to login to your site, but it showed “Error: The username Experthelper is not registered on this site. If you are unsure of your username, try your email address instead.”
    Can you check?
  • apologies i did not hit Save. Now it should be good
  • I’ve modified the condition to be if post meta has value, instead of if post meta exists, and it works now.
