nudnavda
The homepage of this site (see private info) is a standard blog template, with posts containing their entire content.
The template shows 7 posts per page.I have used horizontal tabs in post 1, and vertical tabs in post 7.
The tabs settings of post 1 change the tabs in post 7 to horizontal.
When I enter post 7 the layout is vertical, as intended.The template appears to be influenced by one or more factors that I cannot find.
Thanks for any help! -
That happens because the Tab blocks share the same block ID, which occurs when you copy and paste the block instead of duplicating it.
To fix this, edit either post 1 or post 7, duplicate the tab block, and delete the original one. This should resolve the issue.
nudnavda
Good to know!
Thanks, Alvin. -
You’re welcome!
