Conflicts with smooth scroll and mobile menu
    I have been troubleshooting an issue on my website where when the GeneratePress smooth-scroll is enabled it causes an issue with the mobile menu not pushing the content down when opened. I have attached screenshots.
    As soon as I disable smooth-scroll in the GeneratePress options the issue goes away. I don’t have any other plugins which are causing conflicts, and have extensively tested this.
    First URL – with smooth scroll enabled
    Second URL – with smooth scroll disabled
    Smooth scroll enabled
    Smooth Scroll disabled
    Could you share the site URL so we can take a closer look at the issue?
  • Sure I’ve posted the url in the private section.
  • Try this CSS:
    .both-sticky-menu .main-navigation:not(#mobile-header).toggled .main-nav > ul, .mobile-sticky-menu .main-navigation:not(#mobile-header).toggled .main-nav > ul, .mobile-header-sticky #mobile-header.toggled .main-nav > ul {
        position: relative;
  • That works great, thank you!
    Marking this as resolved.
  • You are welcome   🙂
