Container blocks no longer working in 2.0.1
  • I know others have reported this issue already, but all GB container blocks on our site are no longer supported:
    > Your site doesn’t include support for the “generateblocks/container” block. You can leave it as-is, convert it to custom HTML, or remove it.
    These are the plugin versions we are running:
    GenerateBlocks 2.0.1
    GenerateBlocks Pro 2.0.0
    Can you please issue a fix ASAP, as currently we can’t edit our site unless we convert the blocks to HTML, which we obviously don’t want to do.
    I’m not able to see the plugin list on your site, can you confirm the plugins are active?
    As when I tried to add GB blocks, nothing showed in the editor.
  • Hi Ying,
    Apologies the plugin menu is hidden to admin users by default.
    You might be able to access it directly: with this slug: /wp/wp-admin/plugins.php
    However I can confirm these plugins are installed:
    GenerateBlocks
    Version 2.0.1
    GenerateBlocks Pro
    Version 2.0.0
    GP Premium
    Version 2.3.1
  • Yes, I see both plugins are activated, but none of the GB blocks can be added to the editor.
    I wonder if there’s a plugin/function conlift, do you have a staging site of this live site? If so, can you try disabling all plugin except GB and GB pro to test?
    And switch to the parent theme in case there’s any custom function might’ve affected it.
    Let me know how that goes!
  • OK thanks Ying, I’ll try this and get back to you.
  • Thanks, keep us updated!
