Container-Layout + responsive design
    i have trouble adjusting the responsive layout for this section on the homepage: https://imgur.com/dmDUFTC On mobile it disappears but it’s not set as “hidden” for tablet and mobile. Preferably on tablet + mobile this should stack above each other. I set both containers of the grid to 100% but they’re not stacking.
    The same is happening for this section: https://imgur.com/sOHxHYM
    Since it’s the same topic i hope i can put them both in one topic.
    Thank you!
    The 1st section is there on mobile.
    The 2nd section is missing the image container as the image is added as a background image, so you need to set a min-height for the container so it can occupy some space.
  • The first section i could fix for mobile, thank you 🙂 unfortunately not for tablet since i want them stacked but setting the grid-containers to 100% is not doing it.
    Is it correct that the grid-containers when set to 100% for tablet and mobile they should stack?
    With this section https://imgur.com/sOHxHYM it’s not working and also on some other pages not.
    If you want the section stacked on tablet, select the inner container (gb-element-9cd0650b) and in the tablet breakpoint settings, set Grid Template Columns to 1fr.
  • Yes that worked, thanks.
  • You’re welcome 🙂
