i have trouble to get the grey background container to the correct place according to the desired design: https://imgur.com/Xvt91Gy
I moved the container .gb-element-c490456e with a negative margin up but that’s not working anymore. Please see screenshot: https://imgur.com/2x9COiI
The design of the grey background container also changes on different screen sizes (16′ or 21′). How could i prevent that from happening? On Mobile it doesn’t matter because i will probably just delete the grey background.
Thank you! -
Simply reduce the height of the gray container sohuld work.
Maybe try using relative unit like em,% instead of px.
Lysann
Hi Ying,
it’s almost perfect, just the last section “Berging”.gb-element-2d526104is not aligning like the other ones: please see the screenshot here https://imgur.com/GVmmdJ6. The vertical alignment could be the 1mm you mentioned before but it seems like it’s more like with the other containers. I also can’t find the reason for the different margin.
Also there’s a value in this container of this section.gb-element-7cd1e625ofMax-width: 500pxbut this is useless, no? All the other text-containers have that as well.
Thank you! -
Also there’s a value in this container of this section .gb-element-7cd1e625 of Max-width: 500px but this is useless, no?
It’s not added by me, I didn’t touch that section. yes, it’s useless. You can remove it.
just the last section “Berging” .gb-element-2d526104 is not aligning like the other ones
Both the 3rd and 4th sections don’t look like the 1st and 2nd sections. So there might be some different settings. The easist way is just duplicating the 1st and 2nd sections, and replace the text and image.
Okay i did that and now it’s fine. Thank you Ying!
