Container Link in Query Loop Item
  • I usually use your instructions below for setting up container links:
    https://learn.generatepress.com/blocks/block-guide/add-container-links/#building-our-container-with-link
    However, I have a page that I’ve built where it won’t work. I’ve gone through the instructions multiple times and can confirm I’ve followed all steps, but it’s not adding the link to the entire container (only the first item has the link). Is it because I’m applying it to a loop item block instead of a proper container block?
  • I’ve added a link in the private instructions if you wish to look at the page source. It’s meant to apply to the items in the “New Releases” section.
    You need to set the Position of the Container wrapping the link inside the Loop Item (gb-element-b5fcd1f8) to Default.
  • Okay, it was because another container was also set to relative. I was able to consolidate containers so they weren’t conflicting anymore. Thanks for the help.
  • Glad to hear that!
