Container Padding
  • Hi
    I have a GP Post Template for recipes set up on the site below.
    It includes 2 containers:
    • Ingreditents
    • Method
    with static headings and dynamic text underneath.
    The dynamic text comes from ACF wysiwyg fields (UL and & OL), which has the following code in custom CSS
    /*List Styling on Recipe Posts*/
    body.single-post .dynamic-content-template ol li {
       margin-bottom: 2em !important;
    body.single-post .dynamic-content-template ul li {
       margin-bottom: 1em !important;
    The problem is that it creates too much space at the bottom of each container (where padding would go, but it is probably the list custom CSS).
    When I inspect the CSS, there also seems to be a non-existent <p> line at the bottom of each container.
    Any suggestions for adjusting this would be much appreciated, whether they be CSS-related to the containers or lists.
    Cheers
    Shaun
  • Hi Shaun,
    It seems like the extra padding is caused by an empty paragraph block.
    All you need to do is edit the post template and remove those empty paragraph blocks.
  • Thx Alvind
    Unfortunately, I cannot see the paragraph block in the template. I can only see it when I inspect the CSS in the browser. (It is highly likely me), but have a look at the attached (below) screenshot and see what you can advise
  • It might be coming from the WYSIWYG field. Try checking the field for that post to see if there are any extra <p> tags inside it.
  • Hi Again Alvind
    I haven’t been able resolve the issue through ACF. But I have found a partial solution using the following:
    body.single-post .dynamic-content-template p:last-of-type {
    	display: none !important;
    The CSS fixes the spacing issue. But it hides other paragraph text on the template as well. So, I wanted to see if you could advise how to only apply the above CSS to containers with the class ‘recipe’. See below video for more
  • Try this instead:
    body.single-post .dynamic-content-template #ingredients p:last-of-type,
    body.single-post .dynamic-content-template #steps p:last-of-type {
  • Thx Alvind
    That worked perfectly.
  • Glad to hear that!
