Container Size
  • Hello Support !
    Please go to:
    https://understand-culture.com/
    Click on Countries.
    Choose any country.
    Choose any topic.
    For example Brazil>Agreements:
    https://understand-culture.com/?cat=3300&tag=agreements
    How can I do two things:
    1. Change the width of the container holding the content?
    2. Change the spacing left and right of that container?
    Thanks !
    John
    It would be better to use a Layout element and apply it on certain archives. Can you describe you taxonomy layout? Do you have countries set up as categories?
  • That was fast.
    Thanks, George.
    In the individual posts:
    countries are categories,
    and topics are tags.
    The topic-selections below
    the respective countries in
    the menu are are Custom Links:
    i.e.
    Brazil>Agreements is:
    Does that help?
    Do you need Admin access?
    John
  • Hey John.
    Sure, if you could provide credentials on the private section, I could take a closer look, thanks!
  • Please see below, George.
  • Ok, please edit the Examples layout element and remove All Archives from the Display rules. Add a new location: Post Category Archive -> All categories.
    Then, create another Layout element and set a new location: Post Tag Archive -> All Tags in Display rules, then set your custom width in the Content tab.
  • Thanks, George.
    I think I got it right.
    But most likely not.
    I set the width to 150 px
    to be sure that I can adjust.
    I see not change.
  • Thanks, George.
    I see no change.
  • I can see that even when I set Post Category Archive -> All categories in the element, then Save, it flips back to the Page Category Archive -> All categories.
    This is very strange. I have a suspicion that the AI Engine (Pro) might be causing some issues. Is it ok, if I temporarily disable so I can troubleshoot?
  • Yes, George.
  • By the way … since yesterday
    I have been having problems
    with AI Engine. I hope to hear
    back from their support team.
  • Can I please edit the new element you have created? It seems you are already editing…
  • I am on the backend.
    Let me log out.
  • The pages you want to modify are using URL parameters to filter the content according to category, then tag. This doesn’t allows us to use a Layout element and does not give us different body class to work with.
    You would need to add a code snippet to dynamically add a filtered-archive body class on those pages.
    add_filter( 'body_class', function( $classes ) {
        if ( isset( $_GET['cat'] ) && isset( $_GET['tag'] ) ) {
            $classes[] = 'filtered-archive';
        return $classes;
    Then, you would use this CSS:
    .filtered-archive .grid-container {
        max-width: 500px;
    Change the max-width property value accordingly.
    Let me know how it goes!
    First off, thanks so much for working
    on this on a Saturday !
    This all looks a bit more complicated
    than it needs to be. Isn’t there a simpler
    way to determine the width of the posts,
    and to modify the distance between the
    posts and the container holding the menu?
    John
  • Yes, but this would require to also modify the width of the categories as well, for example on this page
    https://understand-culture.com/category/country/brazil/
    But I assume, you don’t want to that. If you wanted to do that, we could use a Layout Element.
    You are using the WordPress query variable system to display certain tag archives that belong to a certain category, for example
    GeneratePress elements cannot distinguish URL parameters so we could isolate those pages. Neither, WordPress exposes any classes in the body tag so we could target those specific pages. Thus, the code snippet I provided, adds a class ONLY on those pages so we can target them.
Viewing 16 posts - 1 through 16 (of 27 total)
