JB_Walton
I am working on a site, with pages that are build with containers.
Some containers use inside containers that need some background images as well.That works very nice using Generateblocks.
I wanted to use different images as background on mobile view.
After playing around with media css I saw that the Pro version of Generateblocks I liked the idea and bought a license.After installing the pro version I tried this immediately (Advanced!).
Result is that the background images are in front of the container content.
I played with different settings but cannot get it to work properly.Any help would be appreciated.
if the content is placed inside its own Container Block, then you can set its: Layout > Position -> Relative, and then set its
z-index
to a higher value. -
JB_Walton
Thanks for the tip.
Nesting containers was the trick. -
You’re welcome
