mattr2110
Yes. But I see no option to take the page and clone or duplicate it into a post.
Yes I can duplicate a page or a post but this is not what I need.
mattr2110
Seems I need a custom single post template
You can only clone a post to another post, same for the pages, they are different post types.
If you want to create a post template, you should create the layout in a post, not on a page.But anyway, you can also copy all content from the page and paste it into a post. Here’s a video show you how to do it:
https://www.youtube.com/watch?v=CsT1UOzZUgI&t=71s&ab_channel=GeneratePress -
mattr2110
As I’ve said multiple times I cannot create a blog post with the layout I need. If I copy a page to a new post the format is wrong. That is why I’m asking how to create a custom blog post layout.
For example, I copied this page (layout I need)
https://activedirectorypro.com/test2-2/To a new post here
https://activedirectorypro.com/test-page/You can see the post does not look like the page.
Modifying with an element does not work…. so would this be a custom single post template?
It’s because your page’s content container is set to full width, while your post’s content container is set to 800px via a layout element.
If you want to same layout, you need to remove that layout element which limits the content width of a post.
Go to appearance > elements, look for a layout element assigned to posts, and set its status to Draft or pending review, and let me know if the issue is fixed.
mattr2110
I’ve got it figured out. Is there a way to move the entry meta (published on, author) to the end of the post for a specific category?
Can I see one of your posts?
mattr2110
Here is one.
Hi Matt,
Try creating a Hook Element hooked to wp_head. Display it on your preferred pages.
Then, add this code:
<style class="custom-cat-style"> .site-content .inside-article { display: flex; flex-direction: column; } header.entry-header { order:1; } </style>
Let us know how it goes.
mattr2110
That worked. Thank you
You’re welcome, Matt!
