Copy this hero design?
    I wonder if there is a way to copy the hero design in the private info using elements?
    I would like the background to be the featured image, I have made it so far. But I have a hard time getting the container with the title and the design of the container the right way. Could you please give me a hand?
    I just want the title in the white area, no need for the breadcrumbs and the text in the hero image.
    Just to confirm, you want something like this?
    https://app.screencast.com/bICDvv2BcPWOr
  • Hi Ying,
    Yes, exactly!
    -J
    That would require custom CSS. Have you managed to position the title at the bottom left of the container? If so, you can share the page so we can identify the appropriate selector for the CSS.
    I tried, but I really couldnt make it with the new 2.0 correctly. So I would gladly take some help with that as well 🙂
    -J
  • The strcutre would be:
    - container A
      -- container B
       --- container C
         ---- Headline
    Settings:
    Container A:
    – background image
    – overflow-x: hidden
    Container B:
    – max-width to match the rest of the page
    – margin-left:auto, margin-right:auto
    – padding-top: 300px, depends on how tall your want the hero to be
    – padding-left and padding-right: 40px or match your site’s global setting
    Container C:
    – display:inline-block
    – position: relative.
    Container C:before:
    – position: absolute
    – content: ""
    – left: -100vw
    – right: -80px
    – bottom: 0
    – top: 0
    – border radius top right: 20px
    – transform > skew > 12deg
    – background-color: #fff
    Headline:
    – display: inline-block
    – padding-top:20px
    – pdding-right: 0
    – padding-bottom:20px
    – padding-left:0
    Here’s the code, you can switch your editor to code mode, paste it and exit the code mode:
    <!-- wp:generateblocks/element {"uniqueId":"33df9431","tagName":"div","styles":{"backgroundImage":"url(https://new.local/wp-content/uploads/2024/12/0304WedgeML_Snow_LS_004.png)","backgroundSize":"cover","backgroundRepeat":"no-repeat","backgroundPosition":"center","backgroundBlendMode":"normal","overflowX":"hidden"},"css":".gb-element-33df9431{background-blend-mode:normal;background-image:url(https://new.local/wp-content/uploads/2024/12/0304WedgeML_Snow_LS_004.png);background-position:center;background-repeat:no-repeat;background-size:cover;overflow-x:hidden}"} -->
    <div class="gb-element-33df9431"><!-- wp:generateblocks/element {"uniqueId":"93834d8b","tagName":"div","styles":{"maxWidth":"var(\u002d\u002dgb-container-width)","marginLeft":"auto","marginRight":"auto","paddingTop":"200px","paddingLeft":"40px","paddingRight":"40px"},"css":".gb-element-93834d8b{margin-left:auto;margin-right:auto;max-width:var(\u002d\u002dgb-container-width);padding-left:40px;padding-right:40px;padding-top:200px}"} -->
    <div class="gb-element-93834d8b"><!-- wp:generateblocks/element {"uniqueId":"44e40ce5","tagName":"div","styles":{"\u0026:before":{"content":"\u0022\u0022","position":"absolute","top":"0px","left":"-100vw","bottom":"0px","right":"-80px","backgroundColor":"var(\u002d\u002dbase-3)","borderTopRightRadius":"20px","transform":"skew(12deg)"},"position":"relative","display":"inline-block"},"css":".gb-element-44e40ce5{display:inline-block;position:relative}.gb-element-44e40ce5:before{content:\u0022\u0022;position:absolute;top:0px;left:-100vw;bottom:0px;right:-80px;background-color:var(\u002d\u002dbase-3);border-top-right-radius:20px;transform:skew(12deg)}"} -->
    <div class="gb-element-44e40ce5"><!-- wp:generateblocks/text {"uniqueId":"b07ea9ee","tagName":"h1","styles":{"marginBottom":"0px","paddingBottom":"20px","paddingTop":"20px","position":"relative","display":"inline-block","paddingRight":"0px"},"css":".gb-text-b07ea9ee{display:inline-block;margin-bottom:0px;padding-bottom:20px;padding-right:0px;padding-top:20px;position:relative}"} -->
    <h1 class="gb-text gb-text-b07ea9ee">{{post_title}}</h1>
    <!-- /wp:generateblocks/text --></div>
    <!-- /wp:generateblocks/element --></div>
  • Works like a charm! Thank you so much! 🙂
  • One thing though, I wanted to add the breadcrumbs below the page title and then I get this wierd line below. What am I missing?
    On the Container C:before selector, try changing the bottom value to -5px.
  • Got it, works perfect. Thanks!
  • Or, almost perfect. Now I got a scrollbar in the hero section.. How do I get rid of that one?
  • Simply select Container A and set its overflow-y to hidden as well.
  • So easy, thanks Alvind!
  • You’re welcome!
