CPT Archive customization highlighting categories
  • hi Team,
    this is basically a follow up to: https://generate.support/topic/archive-page-with-looping-over-subcategories/
    I’ve followed David’s approach and created an archive-CPT.php for my CPT type (slug) and copied over the archive.php content from the GP theme.
    Starting _simple_ I do want to list all categories (+ their assigned image) prior highlighting the individual list of posts.
    <?php
     * The template for displaying Archive pages.
     * @package GeneratePress
    if ( ! defined( 'ABSPATH' ) ) {
    	exit; // Exit if accessed directly.
    get_header(); ?>
    	<div <?php generate_do_attr( 'content' ); ?>>
    		<main <?php generate_do_attr( 'main' ); ?>>
    			<?php
    			 * generate_before_main_content hook.
    			 * @since 0.1
    			do_action( 'generate_before_main_content' );
    			$subcategories = get_terms( array(
    				'parent' => 0,
    				'taxonomy' => 'CPT-category',
    				'hide_empty' => true)
    			echo '<ul>';
    			foreach ($subcategories as $cat) {
    				$image = get_field('category_image', $cat);
    				if ($image) {
    					echo wp_get_attachment_image($image, 'medium');
    				echo '<li>';
    				echo '<a href="' . get_term_link($cat) . '">' . $cat->name . '</a>';
    				echo '</li>';
    			echo '</ul>';
    This works as expected. Is it possible to use the GP/GB templating to render a template inside the foreach ($subcategories as $cat), allowing me to not fiddle much with CSS\layout in this php file?
    For reference, I’m using GPP,GBP with the new release candidate.
    see lines 58 – 62 of my original GIST:
    https://gist.github.com/diggeddy/c2bdc6190a314238d15bad6979a5ac34#file-category-php-L60
    There is a nested foreach loop which returns the posts for the current category. And within that is the:
    generate_do_template_part( 'archive' );
    That function returns the theme content.php template, which can be overwritten using the GP Element – Content Template.
  • Thank you David, this made it more clear.
    I assume, it is not possible to have a template showing a single card layout (for example) in which I can inject the data? Basically I want to be able to design the container via a template: https://gist.github.com/diggeddy/c2bdc6190a314238d15bad6979a5ac34#file-category-php-L52
    The idea is that I have a some card design based on the categories prior showing the archive page. Something like:
    foreach ($categories as $cat) {
      generate_do_template_part(...)
    Thanks again, David
  • Ah ok.
    It is possible but there are things to consider.
    For example inside your foreach loop you could add your own Hook
    eg.
    do_action('my_custom_hook_name');
    Then you could hook into that using a GP Element, theres an option to choose a Custom Hook where you can type your own hook name
    But… you need to consider how to get the dynamic content you want to display in that template…
  • Yeah this seems to be something I’m keen on.
    Is there a way to use GenerateBlocks_Register_Dynamic_Tag with a list of objects and use them inside a loop?
  • Thank you, I was not able to get it running but embed the content now via a shortcode.
