Create a New Homepage-PoolSwift Theme
    I have revised my knowledge of using blocks and I decided to create a new Homepage for my site using blocks.
    Can I replace the theme homepage with a new one? If yes; how?
    Thank you.
    Regards,
    Celestin
    1. create a new page and build out the new design.
    2. go to Dashboard > Settings > Reading and set the Homepage to display your new page.
    Thank you.
    If Also I want to disable the settings of some part of the original Homepage, to rebuild it without having to start anew; how do I do that?
    Is it possible?
    If Yes, How?
    Thank you.
    Celestin
  • If Also I want to disable the settings of some part of the original Homepage, to rebuild it without having to start anew; how do I do that?
    Edit the homepage, click the 3dots icon on the top right corner, click copy all blocks, create a new page, and paste all blocks in.
    Check this video if you do not understand how to do it:https://www.youtube.com/watch?v=CsT1UOzZUgI&t=11s
    Now on your new page, you can delete things that you don’t want, and modify the rest per your needs.
    Make sure you enable block editor in the Classic editor plugin, or disable the plugin.
    Thank you.
    Cheers,
    Celestin
  • No Problem 🙂
