heat23
I’d like to create a new button (i.e. “Buy now”) that has a consistent style, opens in new tab, rel=”sponsored” but will have a different URL in each post. How can I make this button once but set a different URL each time I use it?I tried installing the “Reuseable Blocks” plugin to create this button, but it isn’t allowing me to customize the URL on each use.
Thanks in advance
Reusable block is a WP built-in feature, I don’t think you would need to install a plugin for that.
When adding a reusable block, you can convert it to a regular block, then you can change its URL and it won’t affect the other buttons.
heat23
Thank you Ying, where in WordPress Admin console do I create this?
Check this WP article:https://wordpress.com/support/wordpress-editor/blocks/reusable-block/
