Raja_panda
Hi David,
I added the shortcode to a footer widget but nothing happens : https://postimg.cc/D4XzyHty
And on my Foot widget, I add the shortcode as “Paragraph” : https://postimg.cc/5X320wkv
Can you confirm that you are using a shortcode block?
https://wordpress.org/documentation/article/shortcode-block/ -
Raja_panda
Oh It wasn’t a shortcode block, only a code block but I changed it and nothing happens.
1. The shortcode PHP code needs to be set to Run everywhere, while you set it to footer.
2. You haven’t assigned a menu to the secondary nav. Check the step 2 in my initial instruction:
https://generate.support/topic/create-sub-menu-in-the-footer/#post-107275 -
Raja_panda
Wow thank you so much I did it with your help. 🙂
Last question : how can I edit the name of the menu “Menu”, https://postimg.cc/yWYvmr5b
I’d like we not to display the word “menu”, just the name of the “Where to play padel” page and the drop-down menu with the cities.
Raja_panda
Sorry I found it, thank you so much guys for your help !!
Raja_panda
Sorry last question :
I accidentally deleted my menu and recreated one.
I don’t understand, on mobile it’s just the way I want it: https://postimg.cc/p9ScyQVd
But on desktop, it doesn’t display as a drop-down menu like Mobile. https://postimg.cc/z3K2XRsJ
Do you know why?
Can you provide a link to the page in question?
Raja_panda
Hello, yes it’s on the homepage (footer). I give you in private information.
Does the current menu has the same structure as the previous one?
Raja_panda
I think so, I create new menu simply
the new menu does not have the same structure as the previous one.
With your current menu structure, all menu items are the parent menu item, there’s no child menu item.
You need to make sure you have a parent menu item:
- parent menu item -- child menu item -- child menu item -- so on... -
Raja_panda
Ok thank you so much. Problem solved.
No Problem 🙂
