sinhere
Apologies if this topic is in the support forum, as I searched for multiple wiki keywords, but I got no results.
I want to create a knowledge wiki page with 3 grids. The left grid has a collapsible list where if a topic is clicked, the information would open up in the center grid, and the right grid would be the shortcut to the topic within the article. A similar site that I have found is from the Mozilla Developer page:
https://developer.mozilla.org/en-US/docs/Web/HTML
Would this be possible to do directly with GenerateBlocks, or do I need to install a wiki plugin? I was thinking of using the accordion block on the left grid or using buttons, but I was wondering how I would be able to connect to the information content for the middle grid and, subsequently, the third grid.
Thank you.
how many pages will this “wiki” have ? And will be you adding more content to it over time, as that would determine whether you could build it statically with blocks or whether a dynamic solution is required.
The way i see this is:
Left Sidebar -> Page Navigation with sub pages
Content
Right Sidebar -> Table of Content PluginLet me know
sinhere
Hi David. The information is regarding the availability of open-source software; right now 11 categories, and each category will probably have up to 10 software listings.
OK, so the left sidebar would be a list of post Category Terms, and nested within a list of the posts right ?
sinhere
That sounds about right, David.
OK, so it would require custom development, so there is a limit on what i can provide.
But i do have a PHP Snippet to create the navigation.1. Add the PHP Snippet provided in this GIST to your site:
https://gist.github.com/diggeddy/58745c3f764cd58716a1c0e153e6626c
This will create a shortcode:
[category_posts]
2. Then in your Customizer > Widgets > Left Sidebar add:
i) a shortcode block and add your
[category_posts]
to it.This will display a list of All Categories in a HTML Detail element that can be toggled open. Within is the related posts. And the current post has a
current-post
class which we can use to keep the detail open and to style the current link.ii) after the shortcode add a HTML Block and add this script:
<script> window.addEventListener('DOMContentLoaded', function() { var listItems = document.querySelectorAll('.current-post'); listItems.forEach(function(listItem) { var detailElement = listItem.closest('details'); if (detailElement) { detailElement.open = true; // Open the detail element } }); }); </script>
This JS will open the relevant detail tab when you click on a post link.
That should do for your left sidebar
Let me know.
The Right Sidebar use the Easy ToC plugin ( or alternative ) to display a table of contents for your post.
sinhere
Wow. Ok thanks so much, David. I will give this a go and let you know. Really appreciate your help.
You’re welcome
