carby
I’m creating a custom header block using Generateblocks Pro and a code snippet to create a shortcode for the nav as explained in this article: https://helwp.com/tutorials/create-your-header-with-generateblocks/
I’ve created a test page here: https://preview.edmontonchambermusic.org/new-header-test/
I can’t figure out why the nav is being repeated. The custom header nav appears below the other. Mobile nav and Sticky nav are turned on. There is a Header element running on other pages but I excluded it from this test page. -
Can I ask why a custom header element is needed here?
The header layout I’m seeing can be done with the theme’s default header.
Let me know if I’m missing something 🙂
carby
I want to create a custom header for the home page and I would like to use blocks to create it. I just started this header to test loading the gp nav so that is why there isn’t much to it yet.
Do you need the sticky navigation feature? The default header shows up because the sticky navigation is activated.
I needed the sticky menu. I couldn’t get it to not show on the home page so I used it where it is and created a hero just for that page.
https://edmontonchambermusic.org/ -
So do you just want to hide the sticky navigation on homepage?
If so, you just need this CSS:
.home nav#sticky-navigation { display: none; }
