“Creator” theme doesn’t appear in site library
  • As the title says… The newest themes (including Creator) are not available when viewing the library within a WordPress installation, so I can’t install the template site. I have an active GP One subscription.
    Can you go to generateblocks > settings, check if you are still using v1 block?
    If so, toggle it off, then go to the site library, scroll to the bottom, click the refresh sites button, you should be able to see all the new templates built with v2 blocks.
    Let me know if this helps!
  • That did it, thanks!
  • You are welcome   🙂
