edirik
There is no spacing between images I add to my blog post and the text coming after. How can I add an automated spacing under (I assume using CSS as ChatGPT generated below but it does not work) image block.
I want to add the spacing for images (Generatepress block and Gutenberg) BUT NOT featured image.
Thanjks,
/* Spacing below image */ .entry-content .wp-block-image img, .entry-content img.wp-image { margin-bottom: 40px; display: block; } -
Could you please share the URL of the page where you want the spacing applied?
That way, I can inspect the setup and give you the exact steps to add spacing under your images without affecting the featured image.
edirik
I want to apply to the entire site not a specific site. See the example below please.
edirik
Also, I want all the images added as “image” block centered horizontally as it is aligned on the left at the moment. Is this also possible?
Thanks,
Please try this CSS under Appearance → Customize → Additional CSS:
/* Spacing applied */ main .wp-block-image { margin-bottom: 40px; } /* Center images */ main .wp-block-image img { display: block; margin-inline: auto; }The first CSS applies the spacing, and the second centres the images.
