CSS mode isn’t showing up
  • The latest plugins are installed, but the icon for CSS mode isn’t showing up in the Block Styles panel. I can’t find any other way to enable CSS mode either.
    All other plugins are disabled.
    Disabling and re-enabling them didn’t help either.
    I’d appreciate any help!
    CSS Mode is only supported in the V2 block system. Looking at your site’s source, it appears you’re still using the V1 block system.
    Whenever you’re ready to migrate to V2 blocks, this guide walks you through the process: https://learn.generatepress.com/blocks/block-guide/generateblocks-1-x-to-2-0/
  • Hi Alvind,
    tanks a lot.
    I have already migrate to V2 blocks since Version 2 was out.
    There is no option to disable V1.
    I have reset via PHP-script and disabled again V1, but there is no CSS Mode.
    The page seems to have a mix of v1 and v2 blocks. Are you sure you are testing on a v2 block? If you could also provide an admin URL so we can login with the credentials you have provided, that would be great (default wp-admin takes me to a 404 page).
  • Hi Georg,
    It should work now –
    I mean: the account should work now !
    All the blocks are see on the page seem to be v1 blocks, meaning they seem to not have been converted. Try creating a new block and you will see the settings. Please, also update GB Pro to the latest 2.6.0 version, as well.
    “Please, also update GB Pro to the latest 2.6.0 version, as well.”
    Great.
    You always have to update it manually?
    Thanks al lot!
    Not always, you should have received a notification for a new version if you license was set up.
    resolved.
    Thanks a lot!
  • Glad to know, no problem!
