CSS not affecting GB Headline
    I am trying to make a GB Headline flash, red and white. I have added `flashing-text’ to the Additional CSS class(es) and added this CSS to the Customiser, but it is not working;
    .gb-headline.flashing-text {
      animation: flashing 2s infinite alternate !important;
    @keyframes flashing {
      0% { color: white !important; }
      50% { color: red !important; }
      100% { color: white !important; }
    I have experimented with adding more simple effects, but it is not targeting the selector. Also tried removing the .gb-headline from start and doesn’t work.
    The Headline is called ‘Hot off the press’ in the Blue Fixtures Box
    Try this one instead:
    .flashing-text > strong {
      animation: flashing 2s infinite alternate;
      0% { color: white; }
      50% { color: red; }
      100% { color: white; }
  • Hey Alvin,
    Tried that and still not working. Its really odd?
  • Did you add the CSS correctly? It works well on my end: https://cln.sh/hmgxCdrK
  • I have added the css to the Customiser. However, the selector part .flashing-text > strong is highlighted in red, which means I believe, that it is not finding the ADDITIONAL CSS CLASS(ES) which is flashing-text
    You can see the css class in developer tools, but it isn’t getting found by customiser.
    However, I have just added this to the Child style.css and it seems to be working. Just not from the Customiser.
    I can live with that, but would be interesting to know why it won’t work from customiser?
  • OK, sound found the issue. The previous CSS in the customeriser had not had not been ended correctly, so the new code was being confused with it. Just a } and it is fixed. Sorry to waste your time, totally a user error!
  • No problem, glad to hear that!
