CSS Specificity in GenerateBlocks 2.0
  • I’m working on a client’s website that I did not build. I’ve done previous updates using GenerateBlocks v1 with no issues. However, it GenerateBlocks v2 has changed enough that I using styles in the editor doesn’t always work.
    Example: in GBv1 an h2 element looks like h2.gb-headline-505f7d00. But in GBv2 that h2 has been dropped so the style is only gb-headline-505f7d00 allowing other styles to take precedence.
    In a nutshell: GBv1 worked great on this website and GBv2 does not.
    Is there anyway to fix this by increasing the specificity of the GBv2 elements?
    Unfortunately, there isn’t a way to do what you asked for.
    Can I see an example of the issue?
  • I can’t override this style on an Elementor site because Elementor prefixes the h2 tag with the .elementor-kit-6 class. Example below.
    .elementor-kit-6 h2 {
    	color: var( --e-global-color-secondary );
    	font-family: "Source Sans Pro", Sans-serif;
    	font-size: 26px;
    	font-weight: 600;
    In GBv1 it added something like this for a class when adding an h2 headline:
    But in GBv2 an h2 headline only produces the class name without the tag name. Example:
    Everything that I built using GBv1 works fine still. Unfortunately, I changed the settings in the plugin to use version 2 block and I can’t roll it back.
  • You can wrap a container outside the headline, and create a new selector h2.gb-text to override the Elementor CSS, the new selector would be .gb-element-xxxxxxxxx h2.gb-text.
    Here’s an example:https://app.screencast.com/Ek6mQRkyc9YlL
