0011.digital
Hi GP Team,
I hope you’re all doing well.
A little over a year ago, I posted a question about having borders, links, text, etc., change color depending on which page the user is on: https://generate.support/topic/change-footer-element-background-on-each-page/
Thanks to your advice, we successfully implemented the solution on our site: https://0011.digital. We’re now able to assign a different color to each page and it works beautifully.
However, a few days ago, we ran our site through a CSS validator:
https://jigsaw.w3.org/css-validator/validator?uri=0011.digital&profile=css3svg&usermedium=all&warning=1&vextwarning=&lang=enAs you can see, the validator is showing multiple (139) “Parse Error” warnings, such as:
1 :root Parse Error –0011-primary-yellow)Here’s a snippet of the CSS code we’re using under Customize > Additional CSS:
/* Color Changes YELLOW */
.blog,
.page-id-2036,
.page-id-4446,
.page-id-2951,
.page-id-5987,
.page-id-6095,
.page-id-8333 {
–main-color: var(–0011-primary-yellow);
}/* Color Changes GREEN */
.page-id-9171,
.page-id-5958,
.page-id-2877,
.page-id-5991,
.page-id-5997 {
–main-color: var(–0011-analogous-green2);
}/* Color Changes RUBY RED */
.page-id-8823,
.page-id-8338,
.page-id-5516,
.page-id-5975,
.page-id-5994,
.page-id-6067 {
–main-color: var(–0011-ruby-red);
We’ve also added the variable in Customizer > Colors like this:CSS Variable Name: main-color
Value: #9EDEE0CSS Variable Name: 0011-primary-yellow
#fff100CSS Variable Name: 0011-ruby-red
#ff0000and so on for each color.
I am not so good at this but the parse error seems to show the code is missing the opening parenthesis,”(” but I am lost as to why or where to fix this, as it is correct in the additioal css (as you can see above).
Another suggestion I saw, was adding this CSS to the top of my additional CSS, but that didnt fix it either./*TESTING THE CSS AUDIT FIXES*/
:root {
–0011-primary-yellow: #fff100;
–0011-sunset-orange: #FD5E53;
–0011-clear-sky: #f2f2f3;
–0011-midnight-blue: #101720;
–0011-analogous-green1: #C0FF00;
–0011-analogous-green2: #56FF00;
–0011-white: #ffffff;
–0011-black: #000000;
–0011-link-hover: #9EDEE0;
–0011-ruby-red: #ff0000;
}We also tried disabling LiteSpeed Cache to rule out minification or caching issues, but the problem persists.
Any guidance would be greatly appreciated.
Thank you for your time,
Richard -
Is there anything wrong on the pages?
If so, can you link me to a page that has the issue and offer more details about the issue?
0011.digital
Hi Ying,
The issues I am reffering to are the ones listed as “parse error” on this report:
https://jigsaw.w3.org/css-validator/validator?uri=https%3A%2F%2F0011.digital%2F&profile=css3svg&usermedium=all&warning=1&vextwarning=&lang=enif this link doesnt work, you should be able to see the same by going to https://jigsaw.w3.org/css-validator/#validate_by_uri and entering 0011.digital (the website)
This is for the URI : https://0011.digital/
I hope this is clear.
best,
R -
If the site is normal, then you can ignore the parse error.
0011.digital
ok, thank you
I will ignore it
best wishes, and thanks for your time as always.
R -
No Problem 🙂
