(CSS) Width doesn’t work as expected, for images with captions
  • Hi team, I’m using CSS to style my blog images. Using Classic Editor. Here’s the code I’m using got:
        /*This one styles right-aligned images WITHOUT caption*/
        .elementor-widget-theme-post-content img.alignright { /*For images inserted by Classic Editor*/
        margin-right: -10vw;
        margin-top: 0.5em;
        margin-bottom: 0.5em;
        /*padding: 0 0.5em;*/ /*commenting this one out but keeping here in case it's useful*/
        width: 40%!important; /*Must add !important or it will not work, likely cuz it's overridden by image size setting in editor*/
        /*This one styles right-aligned images WITH caption*/
       .elementor-widget-theme-post-content .wp-caption.alignright { /*For images inserted by Classic Editor*/
        margin-top: 0.5em;
        line-height: 1.2em;
    What I want is for the image to adhere to a certain fixed width regardless of their actual dimensions. Using this code, if the image has no captions, it’s able to be of a fixed width. However, if it does have captions, the width is only fixed if the image’s actual width is above a certain value. If it’s a smaller image, it will be auto-padded on both sides. I’m not sure how to fix this, but I’m guessing the problem has to do with captioned images belonging to a different parent compared to no-caption images?
    Here are two screenshots:
    No Captions
    With Captions
    The first one is a no-caption image, the second one has captions. Both have the same dimensions when added in Classic Editor, but in the second one, it does not scale/fill the container.
    Your layout seems to be built with the Elementor builder. Please get in touch with their support team for your particular issue.
  • Hi George, thanks for the prompt response. The layout was built with Elementor but I’m quite sure it has no bearing on the issue, as I tested it on a staging site without Elementor and still have the same problem. You’re only seeing the Elementor selector because it’s in an Elementor container, but the classes .wp-caption, .alignright and the img tag are all part of the theme/Wordpress installation.
    I could show you screenshots of the staging site if you’d like to see how it appears there.
  • Can you link us to the page where we can see images with and without caption?
  • Sent, thanks Ying!
    I’ve also cleaned up the CSS code in SimpleCSS so only the part that affects right-aligned images remains.
  • When you add a caption to the WP image block, its structure changes from
    - img
    to
    - figure
     - - img
    And the class alignright and wp-caption are on the figure, not the img anymore.
    If you want to target the image with caption, the selector needs to be .wp-caption.alignright img instead of .wp-caption.alignright.
    Try this CSS:
    figure.wp-caption.alignright img {
        width: 100%;
  • Thanks Ying. I tried that before too, but what I don’t understand is why, when I set the width to 40% for both the no-caption and with-caption selectors, they’re sized differently.
    For the sake of simplicity, I trimmed the code down to this:
        width: 40%;
     img.alignright {
        width: 40%;
    So you’d expect both images to be sized the same, but instead, this is the result.
    screenshot
    I want the captioned image to be sized/scaled the same way as the non-captioned one. My guess is, the captioned image is constrained by a different parent container which has a fixed width?
    Took a look at your page and you’re right, it’s a parent container thing.
    Here’s what’s going on: WP wraps captioned images in a <figure> with an inline style. In your case it’s style="width: 290px" (image width minus 10px of padding that WP adds). Your .wp-caption.alignright { width: 40% !important; } CSS overrides that fine, and the figure ends up at ~516px (40% of the content area). No issues there.
    The problem is the <img> inside. You don’t have a width on it, so it just renders at its natural 300px. Since that’s smaller than 516px, it doesn’t fill the figure – that’s where the extra space is coming from.
    About why your test CSS didn’t behave the way you expected:
    figure.wp-caption.alignright img { width: 40%; }  /* captioned */
    img.alignright { width: 40%; }                     /* non-captioned */
    These look like they should do the same thing, but 40% is relative to different parents. img.alignright is 40% of the content area (~1291px > ~516px). figure.wp-caption.alignright img is 40% of the figure (~516px > ~207px). So the captioned image comes out way smaller.
    Ying’s fix is the right call:
        width: 100%;
    The figure controls the overall size (40% of content), and the image just fills it completely. Same result as the non-captioned version.
  • Thanks Alvind! So if I want the captioned image to also fill 40% of the post content area like the non-captioned image, what should I do?
  • As mentioned, adding this CSS should do it:
        width: 100%;
    Have you tried adding it? The captioned image should then look like this:
    https://cln.sh/9jzzsRynxWFSvFnLbYpY
  • No I’m still not getting it even after adding Ying’s code, so sorry. My images are still differently sized. Could you paste the full code that you have?
    This is what I have in my code (streamlined)
        width: 100%;
  • The CSS I suggested has not been added to your site:
    https://app.screencast.com/tS2PcK35lIcNz
  • Hey Ying! I did add it, but didn’t save it. I was testing it out in the customizer.
    I used the code and this is what it looks like on my end:
    screenshot
    I’ve also saved the code anyway for easier reference.
  • You’ve removed your original CSS, the CSS I suggest is an add-on to your existing CSS.
  • Ahh! Ok now it works, and I also finally understand the previous explanations. Thank you all so much for your help!!
  • You are welcome   🙂
