CTA Blocks
  • why does the call to action blocks in generate blocks pro have to buttons?
    GenerateBlocks Pro doesn’t have a Call to Action block. Perhaps you’re thinking of a block from another plugin?
  • excuse my imprecise language
    Generate Blocks Pro
    pattern library
    CTA
    the cta blocks (maybe they are not blocks so you can help me with the correct name)
    all have 2 buttons
    Why?
    I don’t quite understand your question, it’s called call to action, so it has to have buttons for users to interact with the section.
  • Hi Ying.
    on each block there are two
    I have included an image to show what I mean
    Thanks in advance
  • So? You can use both or delete one or add more.
    These patterns are for you to have a quick start, doesn’t mean you can not edit it.
  • No Problem 🙂
