GuideDolomiti
I’m using GeneratePress on my multilingual WordPress website, and I’m also using WPML to manage translations.
I have created a custom 404 page for each language using the WordPress editor. I was wondering if it’s possible to modify the default GeneratePress 404 behavior so that it loads the appropriate custom page I created, depending on the current language.
Here is the default 404 template code from the theme:
<?php /** * The template for displaying 404 pages (Not Found). * * @package GeneratePress */ if ( ! defined( 'ABSPATH' ) ) { exit; // Exit if accessed directly. } get_header(); ?> <div <?php generate_do_attr( 'content' ); ?>> <main <?php generate_do_attr( 'main' ); ?>> <?php /** * generate_before_main_content hook. * * @since 0.1 */ do_action( 'generate_before_main_content' ); generate_do_template_part( '404' ); /** * generate_after_main_content hook. * * @since 0.1 */ do_action( 'generate_after_main_content' ); ?> </main> </div> <?php /** * generate_after_primary_content_area hook. * * @since 2.0 */ do_action( 'generate_after_primary_content_area' ); generate_construct_sidebars(); get_footer();
Is there a way to make this template redirect or display a specific page I created (depending on the current language) instead of the default 404 template part?
Thanks in advance for your help!
Thank you,
Enrico -
GuideDolomiti
I wanted to follow up on my previous support request regarding setting up a custom 404 page for each language in my multilingual site (using WPML). I have now successfully resolved the issue and no longer require assistance.
Here’s the solution I implemented:
I modified the content-404.php file in my GeneratePress child theme to dynamically load the correct 404 page based on the current language. Here’s the code I used:
<?php /** * Custom multilingual 404 page for GeneratePress. */ if ( ! defined( 'ABSPATH' ) ) { exit; // Exit if accessed directly. } ?> <div class="inside-article"> <?php do_action( 'generate_before_content' ); ?> <header <?php generate_do_attr( 'entry-header' ); ?>> <h1 class="entry-title" itemprop="headline"><?php _e( 'Oops! That page can’t be found.', 'generatepress' ); ?></h1> </header> <div class="entry-content"> <?php // Map custom 404 pages by language $custom_404_pages = [ 'it' => 123, // Italian 404 page ID 'en' => 456, // English 404 page ID 'ja' => 789, // Japanese 404 page ID ]; // Get the current language with WPML $current_lang = apply_filters( 'wpml_current_language', NULL ); // Find the correct 404 page ID $custom_page_id = isset( $custom_404_pages[ $current_lang ] ) ? $custom_404_pages[ $current_lang ] : 123; // Display the content of the custom 404 page echo '<div class="custom-404-page">'; echo apply_filters( 'the_content', get_post_field( 'post_content', $custom_page_id ) ); echo '</div>'; ?> </div> <?php do_action( 'generate_after_content' ); ?> </div>
I still want to thank you, and I hope I didn’t take up too much of your time!
Enrico -
Hey Enrico, I’m glad to hear you managed to find a solution! 🙂
