Davidr
Hello, until now through a plugin it gave me the possibility of giving attributes to blocks, I have seen this section that was not contemplated in generateblock-pro. but I don’t know how to implement it, what am I doing wrong? I don’t want to install plugins and I don’t know if it is possible to show the search button in a specific block as is this case. THANKS IN ADVANCE
data-gpmodal-trigger
gp-search
The attribute is correct, is the nav search modal enabled at customizer > layout > primary navigation?
Davidr
Perfect, it was disabled, now it works. How can I hide the default position of the main menu? I have it configured in a higher block.
You can use this CSS to hide it:
.main-navigation .menu-bar-item > a { display: none; }
Davidr
Ok, perfect, Thank Alvin
You’re welcome!
