Custom breakpoint for a Site Header Menu element
    I am really struggling to get a Menu Element in a Site Header that I created, to switch to a Hamburger Menu at a certain breakpoint.
    Because the Menu Items are many I am trying to switch the Menu to a Hamburger Menu at a fairly high breakpoint; 1700 pixels Viewport width.
    I discovered that the Customizer’s Breakpoint setting doesn’t really affect a GB Pro Site Header element.
    I have tried to follow two of your answers to others with a similar problem, but the CSS I write has no effect.
    Can you help me? If you want to take a look at the Site Header in the question, go to the URL I have provided in the Private Information section. It’s a Global Site Header that I have bulit using the Site Header element.
    Many thanks
    BW Peter
    To set the breakpoint for the Navigation block, you’ll need to configure it in the block’s settings.
    Please refer to this documentation:
    https://learn.generatepress.com/blocks/block/navigation/#navigation
  • Hi Alvind,
    Thank you for that! 🙂
    BW Peter
  • No problem!
