custom field outside the loop
  • Hi, i am trying to output custom text field on current post outside the loop but it is not working.
    {{post_meta key:custom_event_title}}
    custom field is created with ACF. how can i show all type of different fields outside the loop?
    The Post Meta dynamic tag should pull the assigned field as long as the field name is correct.
    Can you provide temporary backend access so I can check why it’s not working?
