Custom Header/Footer Elements Don’t Display on Tag Archives
    I’m working on a local site that uses the latest versions of GeneratePress Premium (with a child theme) and GenerateBlocks Pro. I created block elements that replace the site’s header and footer with custom versions. Both elements are set to display on the entire site with no exclusions.
    The issue I’m having is that neither element will appear on tag archives. The default header/footer still displays.
    I’ve tried changing the elements to hooks and setting a higher priority. That didn’t seem to help. I also tried changing the header to “before_header”, just to see if that would display – it didn’t.
    Category archives seem OK, and I can see the tag archive uses the “archive” body class.
    Do you have any advice for getting this working?
  • Just an update, I’ve got the tags attached to a custom post type. Turns out there was some code that was causing the template issue. I think I’m on the right path.
  • Glad to hear that 🙂
