custom hook
    is it possible to creat a custom hook after the first block of the content?
    thanks
    angel
    that depends what the first block of content is , and whether you want to manually insert the hook or dynamically insert the hook.
    For example:
    a. manually insert a hook using a shortcode
    this PHP Snippet:
    add_shortcode('portable_hook', function($atts){
    	ob_start();
            $atts = shortcode_atts( array(
                'hook_name' => 'no foo'
            ), $atts, 'portable_hook' );
    		do_action($atts['hook_name']);
    	return ob_get_clean();
    And you can add a shorcode like this to generate the hook and name it as you want:
    [portable_hook hook_name="my_custom_hook_name"]
    b. dynamically insert the hook into the content.
    see my reply here:
    https://generate.support/topic/google-ad-before-first-h2/#post-113534
    That inserts a custom hook before the first H2 on a page.
    Let me know what you require.
