Hi
I have a problem with the Custom Post Header.
I used Your code (template) on my test page and it is OK:
<?php
$img_src = wp_get_attachment_image_src( get_post_thumbnail_id( get_the_ID() ), ‘large’, false );
$categories = get_the_category();if ( ! empty( $categories ) ) {
$cat_name = esc_html( $categories[0]->name );
<div class=”custom-hero”>
<div class=”grid-container hero-grid”>
<div class=”hero-column”>
<h1 class=”entry-title”><?php echo get_the_title( get_the_ID() );?></h1>
<?php echo ‘term_id ) ) . ‘”>’ . esc_html( $categories[0]->name ) . ‘‘; ?>
</div><div class=”hero-column”>
<?php echo ‘‘; ?>
</div>
</div>
</div>Then I used the same code on my target page and there it’s not working:
https://snipboard.io/aQyoOd.jpgKr
Robert -
George
Hi Robert,
That output means the PHP isn’t being executed on the target site — the code is being printed as text instead of run. The HTML wrapper around it is rendering fine, so the Hook element itself is working and placed correctly; it’s only PHP execution that’s off.
Two things to check on target domain:
- Open the Hook element (Appearance → Elements) and make sure the Execute PHP checkbox is ticked. It’s off by default on a newly created element, so it’s easy to miss when recreating one on a live site.
- If instead of the checkbox you see the message “Unable to execute PHP as DISALLOW_FILE_EDIT is defined”, PHP in hooks has been disabled site-wide by a constant in your
wp-config.php— often added by a security plugin or by your host. You can re-enable it just for Hook elements by adding this PHP snippet to your site:
add_filter( 'generate_hooks_execute_php', '__return_true' );How to add PHP to your site.
More on the constant.Also double-check the code is in a Hook element — a Block element or a Custom HTML block won’t execute PHP regardless of that setting.
One more thing: the forum stripped part of your code when you posted it (the
<a>tag in the category line was eaten), so I can’t see that line in full. If the above doesn’t sort it, please repost the code wrapped in backticks so it comes through intact.Let me know how you go.
You right – there was the DISALLOW_FILE_EDIT
I addes Your PHP code and now it looks OK
Thx a lot!
R.
George
Ok, no problem!
