Custom post pagination links
    I would like to completely replace current navigation links (next and prev post) within blog single template. Is there any function or hook that I can use to add my own code for this section?
    I would like to add date and some meta fields together with post title, but just need a function or hook in charge for navigation.
    What kind of code are you referring to?
    If you want to create custom paginations, you can use the block element – post navigation.
    https://docs.generatepress.com/article/block-element-post-navigation/
    Let me know if I miss anything 🙂
  • I’m not using blocks.. I need some type of hook or function to completely customise this part from child theme functions.php:
    		<nav <?php generate_do_attr( 'post-navigation', array( 'id' => esc_attr( $nav_id ) ) ); ?>>
    			<?php
    			if ( is_single() ) : // navigation links for single posts.
    				$post_navigation_args = apply_filters(
    					'generate_post_navigation_args',
    					array(
    						'previous_format' => '<div class="nav-previous">' . generate_get_svg_icon( 'arrow-left' ) . '<span class="prev">%link</span></div>',
    						'next_format' => '<div class="nav-next">' . generate_get_svg_icon( 'arrow-right' ) . '<span class="next">%link</span></div>',
    						'link' => '%title',
    						'in_same_term' => apply_filters( 'generate_category_post_navigation', false ),
    						'excluded_terms' => '',
    						'taxonomy' => 'category',
    				previous_post_link(
    					$post_navigation_args['previous_format'],
    					$post_navigation_args['link'],
    					$post_navigation_args['in_same_term'],
    					$post_navigation_args['excluded_terms'],
    					$post_navigation_args['taxonomy']
    				next_post_link(
    					$post_navigation_args['next_format'],
    			elseif ( is_home() || is_archive() || is_search() ) : // navigation links for home, archive, and search pages.
    				if ( get_next_posts_link() ) :
    						<?php generate_do_svg_icon( 'arrow' ); ?>
    						<span class="prev" title="<?php esc_attr_e( 'Previous', 'generatepress' ); ?>"><?php next_posts_link( __( 'Older posts', 'generatepress' ) ); ?></span>
    					</div>
    					<?php
    				endif;
    				if ( get_previous_posts_link() ) :
    						<span class="next" title="<?php esc_attr_e( 'Next', 'generatepress' ); ?>"><?php previous_posts_link( __( 'Newer posts', 'generatepress' ) ); ?></span>
    					</div>
    					<?php
    				endif;
    				if ( function_exists( 'the_posts_pagination' ) ) {
    					the_posts_pagination(
    						array(
    							'mid_size' => apply_filters( 'generate_pagination_mid_size', 1 ),
    							'prev_text' => apply_filters(
    								'generate_previous_link_text',
    								sprintf(
    									/* translators: left arrow */
    									__( '%s Previous', 'generatepress' ),
    									'<span aria-hidden="true">&larr;</span>'
    							'next_text' => apply_filters(
    								'generate_next_link_text',
    								sprintf(
    									/* translators: right arrow */
    									__( 'Next %s', 'generatepress' ),
    									'<span aria-hidden="true">&rarr;</span>'
    							'before_page_number' => sprintf(
    								'<span class="screen-reader-text">%s</span>',
    								_x( 'Page', 'prepends the pagination page number for screen readers', 'generatepress' )
    				 * generate_paging_navigation hook.
    				 * @since 0.1
    				do_action( 'generate_paging_navigation' );
    			endif;
    		</nav>
    With link I want to add some custom meta and other items…
  • Hi Adaba,
    To clarify, are you looking to create something like what’s created here: https://docs.generatepress.com/article/block-element-post-navigation/ – but through custom code?
  • exactly, since I’m not using blocks.. just need some hook or function that will access navigation part so I can add my own code there…
  • I see. The default one can be disabled through Appearance > Customize > Layout > Blog. Reference:
    Then, you can hook your code through a Hook Element hooked to after_content or somewhere else you prefer. Reference: https://docs.generatepress.com/article/hooks-visual-guide/#single-post
  • Ok that makes sense.. I will try that approach.. Thanks
  • You’re welcome, Adaba!
