chicablue
Im using forminator and Im trying to use custom forms to register and login to my website.
I created a login page and another one for registration. Should I use the same address for both?
I understand I need to add a code in functions.php to redirect users to these pages but Im unsure if I need to use 2 addresses or 1.
Thanks for the information. -
Registration and login should be on different URLs.
chicablue
Is it possible to create custom forms (registration / login, etc) with generatepress / blocks without having to use a plugin?
If not, do you have a light one to recommend that can be integrated with mailing services and such? -
No – that’s not what GP and GB are built for.
We don’t have a recommendation for this. Please do some research and try a few option so determine which one works for you the best.
In terms of speed and performance, simply run your site through speed test before and after the plugin implementation.
Hope this helps.
