erwinmedia
I am currently building a website with GB 2.0. It looks really cool, but a lot has also changed. I’m looking for a solution for the following situation:
I have a container inside another container. The inner container contains a background image. I assign a CSS class to this container, for example, “x”.
I want this background image to have an effect when I hover over the outer container. Previously, I did this using a custom selector, where I specified the class of the inner container.
I no longer see the option for a custom selector.
How can I solve this now?
1. Select the outter container, go to the style panel, click the More button at the top of the right sidebar to open the selectors panel, click +New to create a new selector, then enter
:hover .x
in the selector field, toggle the Compond selector option, it will create a selector as.gb-element-xxxxx:hover .x
.2. Now you can add your effect to this selector.
Let me know if everything is clear 🙂
erwinmedia
Hi Ying, thanks. That worked. Can you please check the url and tell me how I can keep the image inside the blue box?
You can select the container with class
gb-element-b1ec905b
and setoverflow-y
tohidden
