Custom template for each category (block – content template)
  • I created a template for each category. In it, I use a grid for posts with Content Views Pro. I also have separate widgets for each category that sort posts by ACF. However, the category page duplicates entries using the built-in GeneratePress loop. I tried to disable them with the code below, but it didn’t help.
    PHP
    add_filter( 'generate_do_template_part', function( $do ) {
        // Checks if the current page being viewed is a category archive page
        if ( is_category() ){
            // Setting $do to 'false' tells GeneratePress NOT TO DISPLAY the default loop
            $do = false;
        return $do;
    When you say “I created a template for each category”, is the template a PHP template or block based template?
    Can you explain some more about your setup? And please link us to the page in question.
  • Each category has own block template and custom widgets with filters and custom category tags. https://blog.konspo.eu/kategoria/okna/
    I’m not sure how Content Views Pro handles archive templates, but I assume it has an option to disable additional loops in its settings. Have you checked if that option is available?
  • However, if I use only the theme’s built-in query loop, without Content View Pro, posts are still duplicated. The theme settings include options for customizing the appearance of the post archive, and they appear automatically.
  • Is it possible for you to provide a temporary admin login to your site so we can take a closer look?
  • I’ve successfully set up my archive using the **GenerateBlocks Query Loop** (Block Archive Card) after removing the old content view, and it’s working well.
    However, I’m now experiencing a common issue when using **FacetWP** for filtering:
    1. When I **check** one or more filtering options in the sidebar (FacetWP), the results list correctly filters down.
    2. The problem occurs when I **uncheck** the filter options to return to a larger set of posts. The two-column grid layout is **lost**, and all posts are displayed in a single column, stacked one above the other.
    This issue seems to be related to how the **AJAX refresh** of the FacetWP template interacts with the **CSS Grid/Flex** structure applied by GenerateBlocks (or GeneratePress) on the post list. The necessary column classes (e.g., grid-50 or GenerateBlocks grid classes) are not being correctly re-applied or re-initialized after the AJAX reload.
    You can see the issue live here: https://blog.konspo.eu/kategoria/okna/
    Could you please advise on the recommended method or a JavaScript hook to ensure the two-column grid layout remains intact after a FacetWP AJAX operation?
    Thank you for your help!
    The posts in the page you linked are not created via GB’s query block. Am I missing anything?
    If you’ve done the change, can you make sure all cache is cleared? I’m probably seeing the cached version.
    This is what I see: https://app.screencast.com/yXLqsxw318dwT
