Customize not working
  • Hey guys,
    I’ve just finished building my new site. Everything was working great, but suddenly in the WP backend, the “Customize” page is no longer working under Appearance.
    I’ve not changed the PHP version or anything meaningful. Plugins/themes are all updated. Site Health is good.
    Only two plugins have been installed recently, both of which I’ve disabled, and still not working.
    Can’t for the life of me work out what it might be.
    Is nothing loading at all? Just a white page?
    If so, can you check the error_log file on your server to see if there’s a recent entry that may be relevant to share?
    Let us know 🙂
  • It gets this far: https://ibb.co/VVxZv0Q
    The menu does not load and the window/tab just freezes.
    Nothing of note in the error_log
  • If you right-click the page and open the “Console” tab, does it show any errors?
    Usually, this happens when there’s some sort of PHP error on the page. Do you have WP_DEBUG turned on?: https://developer.wordpress.org/advanced-administration/debug/debug-wordpress/
  • Console doens’t show any relevant errors.
    I turned DEBUG on, and got the following on every page of my website:
    Deprecated: Creation of dynamic property CDN_Cache_Admin::$purge_cache is deprecated in /home/dm9rauj/public_html/wp-content/mu-plugins/cdn-cache-management/includes/cdn-cache-admin.php on line 14
    Deprecated: Creation of dynamic property CDN_Cache_Admin::$purge_cache_message is deprecated in /home/dm9rauj/public_html/wp-content/mu-plugins/cdn-cache-management/includes/cdn-cache-admin.php on line 15
    This is a plugin installed by my host – Rocket.net
    But it’s happening throughout the site, so shouldn’t be specific to the Customize page.
    I think Rocket should be able to help with this issue since the error seems to be related to their plugin. Have you reached out to their support team?
  • Hi Alvind, thanks for the response.
    Yes I reached out to them. Apparently it’s a system wide issue affecting all their clients, but isn’t causing the Customize not to work. The Customize page is working on my other sites with them (all of which are using GP).
  • Could you provide a temporary admin login so we can check and test some things on the site?
  • Seems the issue was BetterDocs plugin. Rocket managed to work that out. Very odd.
    Thanks for the help!
  • Glad to hear that!
