Customize screen error
  • When I click on the customise tab I am getting the following error. Any thoughts on how to fix this?
    \n
    								data.attachment.alt ?
    									wp.i18n.sprintf(
    											wp.i18n.sprintf(
    <# print( 'Caitlin Grace Photo' ) #>
    <# if ( data.canUpload ) { #> Remove Change image <# } #>
    <# } else { #>
    <# if ( data.canUpload ) { #> Select Site Icon <# } #>
    <# if ( data.defaultAttachment ) { #> Default <# } #>
    <# } #> <# if ( data.description ) { #>
    {{{ data.description }}}
    can you temporary disable all other plugins to see if there is a conflict?
  • Fixed thank you David
  • Was it a plugin causing the issue ?
