Customized Logo Placement
  • Hello Support !
    Please see UC at:
    https://understand-culture.com/
    See the semantic search box placed right in the middle of the landing page.
    I would like to place the UC logo (see top left corner of the site) just above that box. See Perplexity: https://www.perplexity.ai
    The UC logo, however, is not a graphic. Instead it is two words slapped together — understandculture — with understand in dark gray (not sure which #BA) and culture in #BA1800.
    Can this be done?
    Thanks.
    John
  • Hi John,
    Try adding a container block where you want to insert the title, and add a custom HTML block into the container, then add this HTML:
    <p class="main-title" itemprop="headline">
    	<a href="https://understand-culture.com/">Understand <br><span class="site-title-accent">Culture</span></a></p>
    Set the container’s display to flex, justify-content to center, and link color to #515151.
  • Holy Moses, Ying, are you fast !
    Just got from my evening walk in
    the cold, fresh air here in Bonn
    and see your response. Thanks.
    Ok, I think have just about all
    of it right. However, the logo is
    compressed, and both words are in
    #ba1800, whereas “understand” needs
    to be in gray. See the logo at top-
    left of the website.
    Here is what the text page looks like:
    https://understand-culture.com/119086-2/
    John
  • You are welcome John 🙂
    It looks like my code has an extra > in the end. Can you remove that?
    Regarding the color issue, did you set the container’s link color to gray? I don’t see it being applied based on the front end result.
  • Hi Ying,
    The extra > was my error.
    I did not copy/paste properly.
    The log needs the two words
    slapped together: understandculture.
    With understand in dark gray
    and culture in #ba1800.
    Thanks.
  • Let’s try replacing the previous HTML with this new one:
    <p class="main-title" itemprop="headline">Understand <br><span class="site-title-accent">Culture</span></p>
    Let me know if this works!
  • Perfect, Ying.
    Ok, now let’s flatten out the
    logo so that it reads:
    UNDERSTANDCULTURE
    You truncated the logo in the
    top-left corner, I think, because
    the width of the menu margin is
    narrow.
  • Ok, now let’s flatten out the
    You can remove the <br> tag from the HTMl 🙂
  • Perfect, Ying !
    One last question . . . is it possible
    to reduce the space between
    the logo and the search box?
    And, do I have control over the
    font size of the logo?
  • You can set the font size at customizer > typography > typography manager > add new > custom selector, then enter .entry-content .main-title.
    The space between the title and the search box is from the search box itself; we don’t have control over it.
    https://app.screencast.com/Z53eufiLgP3Kx
    You can try reaching out to the form provider or use this CSS to override the form’s default style:
    .mwai-theme-i2inee-theme .mwai-conversation {
        padding-block: 0;
  • Perfect.
    Thanks, Ying !
    John
  • You are welcome   🙂
