Customizing certain appearance elements via CSS
  • Hello!
    I’d like to know how to customize via CSS the following features (it’s nice to have it adjusted via Appearance->Customize, nevertheless I’d also like to know how to do it via CSS):
    1. Layout -> Container -> Separating Space
    2. Layout -> Container -> Content Separator
    3. Layout -> Container -> Content Padding (Left, Right, Top, Bottom)
    4. Layout -> Header -> Header Padding (Left, Right, Top, Bottom)
    5. Layout -> Primary Navigation -> Menu Item Width
    6. Layout -> Primary Navigation -> Menu Item Height
    7. Layout -> Primary Navigation -> Sub-Menu Item Width
    8. Layout -> Primary Navigation -> Sub-Menu Item Height
    9. Layout -> Sidebars -> Widget Padding
    10. Layout -> Sidebars -> Left Sidebar Width
    11. Layout -> Sidebars -> Right Sidebar Width
    12. Layout -> Footer -> Footer Wdiget Area Padding
    13. Layout -> Footer -> Footer Padding
    14. Layout -> Footer -> Copyright
    Thank you!
    You can mostly control those settings via Appearance → Customize → Layout (Container, Header, Navigation, Sidebars, Footer). GP Premium’s Spacing module covers container padding, header padding, etc.
    I’d recommend using the Customizer settings where possible, since that’s the easiest and most reliable way.
    If you still prefer to override via CSS, here are examples for some of them:
    /* Container content padding */
    .site .inside-article {
      padding: 20px 30px; /* top-bottom, left-right */
    /* Header padding */
    .site-header {
      padding: 15px 25px;
    /* Primary nav menu item width / height */
    .main-navigation ul.menu > li > a {
      min-width: 120px;
      height: 50px;
      line-height: 50px; /* vertically align text */
    /* Sub-menu item width / height */
    .main-navigation .sub-menu li a {
      min-width: 150px;
      height: 40px;
      line-height: 40px;
    /* Sidebar widget padding */
    .widget {  padding: 15px;
    /* Sidebar widths */
    .widget-area-left {
      width: 25%;
    .widget-area-right {
      width: 25%;
    /* Footer widget area padding */
    .footer-widgets {
      padding: 30px 20px;
    /* Footer main padding */
    .site-footer {
      padding: 20px 0;
    /* Copyright area */
    .site-info {
      padding: 10px 0;
  • Thanks much! Have a good one!
