Data Collection Above the Fold
  • Hi.
    I’m using a generate press theme (Scribe) but need to move beyond its blog post homepage.
    Could you explain how I would borrow the hero elements from other themes (e.g. Bold & Coach) and insert a newsletter subscription form above the fold using Gravity Forms?
    Thank you.
    Stuart
  • Hi Stuart,
    On the Scribe page, this part is a page hero inserted to the blog page via a block element – hook:
    https://app.screencast.com/buIHmny9WsuRA
    You can edit this block element (Home Page Intro), modify the style and insert your form there.
    If you want to use the page hero from Bold or Coach, I would recommend import them to a blank site, then you can copy the block in the page hero and paste it to your Scribe site’s block element.
  • Thank you Ying.
    I think I’d like to do the second of those – are you able to give me a step-by-step guide as to how to do it? I wouldn’t know where to start.
    Thank you.
  • The 2nd option requires a blank staging site, do you have one available?
    A. If so, you can go to the site-library and import the site.
    Both Coach and Bold templates’ heroes are built directly in the page editor.
    1. select the container which contains the hero section.
    2. click the 3 dots icon in the floating toolbar.
    3. click copy block and go to your other site.
    4. edit the Home page Intro element, remove the existing container, add a paragraph block, and then paste the copied container there.
    B. If you do NOT have a blank site, you can copy the code from below links, and switch your element editor to code editor (click the 3 dots icon on the top right corner of the screen, click code editor), paste the code, then click exit code editor.
    Bold hero code: https://pastebin.com/0Z4F1x9A
    Coach hero code: https://pastebin.com/uVrkSPMz
  • Ying, you’re a genius! And a credit to Generate Press.
    Thanks for all your help, it’s made my day.
  • Awesome 🙂 Glad to hear that!
    Let me know if I can close this topic.
  • Sorry Ying, one more thing – how would I remove the picture on mobile?
  • You can add hide-on-mobile class to the block that you want to hide on mobile.
    Adding CSS class to blocks: https://wordpress.com/support/wordpress-editor/adding-additional-css-classes-to-blocks/
