Date archive (day) shows all posts instead of just the ones of that day
  • For a website I need to use the default WordPress calendar widget. In that calendar each day that has posts links to that specific day and should display a date archive (day) of posts of only that specific day. The permalink is https://domainname.com/2023/06/05/ (website is still under construction)>
    Instead of showing the posts of that day, the page always shows all posts, no matter what day or month. I haven’t used this widget the last 10 years 😉 so I’m not sure where the error lies. I created an archive loop that shows 6 posts and condition is Date Archive.
    Am I overlooking something (very obvious) ?
    As this is a WP core widget, GP doesn’t have control over it.
    I just tested the widget on my site and it works normaly.
    I would recommend disabling all your plugins to eliminate conflicts with other plugins, if the issue’s fixed, turn the plugin on one at a time to see which one is causing the issue.
    If you are using a child theme, switch back to the parent GP theme to eliminate conflicts from custom functions.
  • Hello Ying,
    I’m not sure. I deactivated all plugins and the calendar indeed works correct then. But it also works correct when just deactivating the Element I created to show my date archives, so there is something wrong in my Element settings.
    The Element I called Date loop has a standard Query loop that shows posts. The location I set to Date Archives. But instead of showing just the posts of a specific day (https://domainname.com/2023/06/05/), it shows all posts.
    the Query Loop block you have in your element, does it have any parameters set ?
  • Hi David, At the moment there are no parameters set. One time I had a few set, like the order (ASC) and orderby Date, but that had the same result. I don’t see any other parameters that could make a difference.
  • Aaaaaah…. Of course…. stupid me, I know I read this and totally forgot. Thanks! Now it works :).
  • You’re welcome!
