Topfgartenwelt
is it possible to edit the following code so that it appears before the H1 of each post?
add_filter( 'generate_post_date_output', function( $output, $time_string ) { if ( is_single() ) { $time_string = '<span class="date-label">veröffentlicht </span><span><time class="entry-date published" datetime="%1$s" itemprop="datePublished">%2$s </time></span>'; $updated_time = get_the_modified_time( 'U' ); $published_time = get_the_time( 'U' ) + 86400; if ( $updated_time > $published_time ) { $time_string .= '<span class="date-label"> - aktualisiert </span><span><time class="entry-date updated-date" datetime="%3$s" itemprop="dateModified">%4$s </time></span>'; } $time_string = sprintf( $time_string, esc_attr( get_the_date( 'c' ) ), esc_html( get_the_date() ), esc_attr( get_the_modified_date( 'c' ) ), esc_html( get_the_modified_date() ) ); } return $time_string; }, 10, 2 );
Thank you very much!
Greetings Kathrin
Hi Kathrin,
A different code or solution would be needed to move the date. The code or solution would depend on your Posts’ structure.
For reference, can you share a link to a Post on your site?
Topfgartenwelt
Than I will close that topic again, because than we have to solve it in connection with the featured image 🙂
Greetings Kathrin
You’re welcome! Yes, this seems related to your other topic as well. We can address it there.
