Design issues
  • Hello everyone,
    I’m hoping to get some assistance with two design problems I’m encountering in WordPress. I’ve attached screenshots to better illustrate the issues—one from the backend and the other from the frontend.
    In the backend, I can see the desired layout, but when I save and view it on the frontend, the layout changes and becomes misaligned. What can I do to correct this problem?
    How can I adjust the spacing after the text “AVALIACAO GERAL” with the stars? I’d like to reduce the space that appears afterward, but I’m having trouble achieving this.
    Any help or guidance on resolving these issues would be greatly appreciated. Thank you in advance!
    Best regards
    Url : https://bomcelular.com.br/samsung-galaxy-s21-fe/
    Screnshot
    https://imgbb.com/7GdjF3Y
    https://imgbb.com/QnmrFPD
    see here:
    https://app.screencast.com/mZ5LMmrBQLQLy
    The two Container Blocks are set to Align Wide , set them to Default.
    Align Wide should only be used on top level blocks, to overcome container padding.
    Also you may want to consider using a GB Grid Block instead of the Columns block….
  • Hi David, thanks for your response, so I also tried with GP Gird. I can’t get any white space between the two columns. and my other problem I cannot use GP GIRD to have the same height of gray backround. Thank you very much for your help
  • I can’t get any white space between the two columns.
    Select the Grid block, you can set horizontal gap and vertical gap.
    Yes, you can.
    https://docs.generateblocks.com/article/equal-height-grid-containers/
