thorsolutions
Hi there.
The design tokens are a very welcomed addition to GenerateBlocks, great work!It would be amazing if there was a way to import the variables from theme.json, which are already “tokens”, to GenerateBlocks tokens. Maybe into a custom category, reserved for theme.json, as read-only tokens.
Is there a way to do this? If not, are you planning on adding such functionality or something similar in the near future?
Thanks!!
Glad to hear you like the design tokens!
There isn’t a way to import
theme.jsonpresets as tokens at the moment, and there’s no read-only token type either. Could you post it as a feature request at https://feedback.generatepress.com/ so our team can consider it?For colors, the
theme.jsonpalette is already available in the GenerateBlocks color picker under the “Theme” group, so you can use those without creating tokens. -
thorsolutions
Hi there, and thanks for the quick reply!
It would be great if spacings and font sizes behave like the colors.
I’ll add a feature request.
Sure, no problem! 🙂
