Device Visibility Toggle No Longer Working After the Latest Update
  • Horst Schulte
    Since the latest update, the Device Visibility option in GenerateBlocks no longer works correctly.
    I’m referring to the toggle shown in the attached screenshot (e.g. “Hide on Tablet & Mobile”). Regardless of which option is selected, the block is no longer hidden on the corresponding devices.
    I’ve attached a screenshot so you can see exactly which setting I mean.
    Could you please check whether this is a known issue or if there’s a workaround?
    Thank you very much for your support.
    Kind regards,
    Horst Schulte
  • Hi there.
    It seems that you haven’t attached any screenshot, can you try again?
    Can you please list the GenerateBlocks and GenerateBlocks Pro version numbers that you have installed?
    I can not reproduce this locally. What kind of block are you working with? Can you try a simple text block and see if visibility conditions work there?
    If not, please disable all plugin apart from GB and GB Pro and see if that fixes the issue, then activating them one by one. You might have to try this on a staging site.
